你不会是程序猿吧?
elastic spark
elastic spark
elastic-spark classNotFount EsSpark
Elasticsearch • easesstone 发表了文章 • 4 个评论 • 3687 次浏览 • 2017-09-11 16:07 • 来自相关话题
报错如下: java.lang.ClassNotFoundException: org.elasticsearch.spark.rdd.EsSpark$$anonfun$doSaveToEs$1 at java.net.URLClassLoader.findClass(URLClassLoader.java:381) at java.lang.ClassLoader.loadClass(ClassLoader.java:424) at java.lang.ClassLoader.loadClass(ClassLoader.java:357) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:348) at org.apache.spark.serializer.JavaDeserializationStream$$anon$1.resolveClass(JavaSerializer.scala:66) at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1613) at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1518) at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1774) at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1351) at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:2000) at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1924) at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1801) at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1351) at java.io.ObjectInputStream.readObject(ObjectInputStream.java:371) at org.apache.spark.serializer.JavaDeserializationStream.readObject(JavaSerializer.scala:71) at org.apache.spark.serializer.JavaSerializerInstance.deserialize(JavaSerializer.scala:97) at org.apache.spark.scheduler.ResultTask.runTask(ResultTask.scala:63) at org.apache.spark.scheduler.Task.run(Task.scala:90) at org.apache.spark.executor.Executor$TaskRunner.run(Executor.scala:253) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745)  写了一个elasticspark demo  如下: ``` package com.sydney.dream.elasticspark import org.elasticsearch.spark._ import org.apache.spark.{SparkConf, SparkContext} /**   * 需要手动引入org.elasticsearch.spark._   * 这样使得所有的RDD 都拥有saveToEs 的方法   */ object ElasticSparkFirstDemo {     def main(args: Array[String]): Unit = {         val conf = new SparkConf()             .setAppName("ElaticSparkFirsDemo")             .set("es.nodes", "172.18.18.114")             .set("es.port", "9200")             .set("es.index.auto.create", "true")         val sc = new SparkContext(conf)         val numbers = Map("one" -> 1, "two" -> 2, "three" -> 3)         val airports = Map("arrival" -> "Otopeni", "SFO" -> "San Fran")         sc.makeRDD(Seq(numbers, airports)).saveToEs("spark/docs")     } }     pom 文件如下: <?xml version="1.0" encoding="UTF-8"?> <project xmlns="http://maven.apache.org/POM/4.0.0&quot;          xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;          xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/ma ... gt%3B     <parent>         <artifactId>spark</artifactId>         <groupId>com.sydney.dream</groupId>         <version>1.0.0</version>     </parent>     <modelVersion>4.0.0</modelVersion>     <groupId>com.sydney.dream</groupId>     <artifactId>ElasticSpark</artifactId>     <dependencies>         <!--<dependency>             <groupId>org.elasticsearch</groupId>             <artifactId>elasticsearch-hadoop</artifactId>             <version>5.5.0</version>         </dependency>-->        <dependency>             <groupId>org.elasticsearch</groupId>             <artifactId>elasticsearch-spark-20_2.10</artifactId>             <version>5.5.0</version>         </dependency>         <dependency>             <groupId>org.apache.spark</groupId>             <artifactId>spark-core_2.10</artifactId>             <version>2.2.0</version>         </dependency>         <!--<dependency>             <groupId> org.apache.storm</groupId>             <artifactId>storm-core</artifactId>             <version>1.0.1</version>             <exclusions>                 <exclusion>                     <groupId>org.slf4j</groupId>                     <artifactId>log4j-over-slf4j</artifactId>                 </exclusion>             </exclusions>         </dependency>-->     </dependencies>    <build>         <plugins>             <plugin>                 <groupId>org.apache.maven.plugins</groupId>                 <artifactId>maven-jar-plugin</artifactId>                 <version>2.6</version>                 <configuration>                     <archive>                         <manifest>                             <addClasspath>true</addClasspath>                             <classpathPrefix>lib/</classpathPrefix>                             <mainClass>com.sydney.dream.elasticspark.ElasticSparkFirstDemo</mainClass>                         </manifest>                     </archive>                 </configuration>             </plugin>             <plugin>                 <groupId>org.apache.maven.plugins</groupId>                 <artifactId>maven-dependency-plugin</artifactId>                 <version>2.10</version>                 <executions>                     <execution>                         <id>copy-dependencies</id>                         <phase>package</phase>                         <goals>                             <goal>copy-dependencies</goal>                         </goals>                         <configuration>                             <outputDirectory>${project.build.directory}/lib</outputDirectory>                         </configuration>                     </execution>                 </executions>             </plugin>            <plugin>                 <groupId>org.scala-tools</groupId>                 <artifactId>maven-scala-plugin</artifactId>                 <version>2.15.2</version>                 <executions>                     <execution>                         <goals>                             <goal>compile</goal>                             <goal>testCompile</goal>                         </goals>                     </execution>                 </executions>             </plugin>             <!--             <plugin>                 <groupId>org.apache.maven.plugins</groupId>                 <artifactId>maven-shade-plugin</artifactId>                 <version>2.4.1</version>                 <configuration>                     <createDependencyReducedPom>false</createDependencyReducedPom>                 </configuration>                 <executions>                     <execution>                         <phase>package</phase>                         <goals>                             <goal>shade</goal>                         </goals>                         <configuration>                             <transformers>                                 <transformer implementation="org.apache.maven.plugins.shade.resource.ManifestResourceTransformer" />                                 <transformer implementation="org.apache.maven.plugins.shade.resource.ServicesResourceTransformer"/>                             </transformers>                         </configuration>                     </execution>                 </executions>             </plugin>-->         </plugins>     </build> </project>     spark-submit 提交:  spark-submit --class com.sydney.dream.elasticspark.ElasticSparkFirstDemo --master yarn --deploy-mode client --executor-memory 5G --num-executors 10 --jars /home/ldl/sparkdemo/ElasticSpark-1.0.0.jar  /home/ldl/sparkdemo/lib/activation-1.1.1.jar /home/ldl/sparkdemo/lib/antlr4-runtime-4.5.3.jar /home/ldl/sparkdemo/lib/aopalliance-repackaged-2.4.0-b34.jar /home/ldl/sparkdemo/lib/apacheds-i18n-2.0.0-M15.jar /home/ldl/sparkdemo/lib/apacheds-kerberos-codec-2.0.0-M15.jar /home/ldl/sparkdemo/lib/api-asn1-api-1.0.0-M20.jar /home/ldl/sparkdemo/lib/api-util-1.0.0-M20.jar /home/ldl/sparkdemo/lib/avro-1.7.7.jar /home/ldl/sparkdemo/lib/avro-ipc-1.7.7.jar /home/ldl/sparkdemo/lib/avro-ipc-1.7.7-tests.jar /home/ldl/sparkdemo/lib/base64-2.3.8.jar /home/ldl/sparkdemo/lib/bcprov-jdk15on-1.51.jar /home/ldl/sparkdemo/lib/chill_2.10-0.8.0.jar /home/ldl/sparkdemo/lib/chill-java-0.8.0.jar /home/ldl/sparkdemo/lib/commons-beanutils-1.7.0.jar /home/ldl/sparkdemo/lib/commons-beanutils-core-1.8.0.jar /home/ldl/sparkdemo/lib/commons-cli-1.2.jar /home/ldl/sparkdemo/lib/commons-codec-1.8.jar /home/ldl/sparkdemo/lib/commons-collections-3.2.2.jar /home/ldl/sparkdemo/lib/commons-compiler-3.0.0.jar /home/ldl/sparkdemo/lib/commons-compress-1.4.1.jar /home/ldl/sparkdemo/lib/commons-configuration-1.6.jar /home/ldl/sparkdemo/lib/commons-crypto-1.0.0.jar /home/ldl/sparkdemo/lib/commons-digester-1.8.jar /home/ldl/sparkdemo/lib/commons-httpclient-3.1.jar /home/ldl/sparkdemo/lib/commons-io-2.4.jar /home/ldl/sparkdemo/lib/commons-lang-2.6.jar /home/ldl/sparkdemo/lib/commons-lang3-3.5.jar /home/ldl/sparkdemo/lib/commons-math3-3.4.1.jar /home/ldl/sparkdemo/lib/commons-net-2.2.jar /home/ldl/sparkdemo/lib/compress-lzf-1.0.3.jar /home/ldl/sparkdemo/lib/curator-client-2.6.0.jar /home/ldl/sparkdemo/lib/curator-framework-2.6.0.jar /home/ldl/sparkdemo/lib/curator-recipes-2.6.0.jar /home/ldl/sparkdemo/lib/gson-2.2.4.jar /home/ldl/sparkdemo/lib/guava-16.0.1.jar /home/ldl/sparkdemo/lib/hk2-api-2.4.0-b34.jar /home/ldl/sparkdemo/lib/hk2-locator-2.4.0-b34.jar /home/ldl/sparkdemo/lib/hk2-utils-2.4.0-b34.jar /home/ldl/sparkdemo/lib/htrace-core-3.0.4.jar /home/ldl/sparkdemo/lib/httpclient-4.3.6.jar /home/ldl/sparkdemo/lib/httpcore-4.3.3.jar /home/ldl/sparkdemo/lib/ivy-2.4.0.jar /home/ldl/sparkdemo/lib/jackson-annotations-2.6.5.jar /home/ldl/sparkdemo/lib/jackson-core-2.6.5.jar /home/ldl/sparkdemo/lib/jackson-core-asl-1.9.13.jar /home/ldl/sparkdemo/lib/jackson-databind-2.6.5.jar /home/ldl/sparkdemo/lib/jackson-jaxrs-1.9.13.jar /home/ldl/sparkdemo/lib/jackson-mapper-asl-1.9.13.jar /home/ldl/sparkdemo/lib/jackson-module-paranamer-2.6.5.jar /home/ldl/sparkdemo/lib/jackson-xc-1.9.13.jar /home/ldl/sparkdemo/lib/janino-3.0.0.jar /home/ldl/sparkdemo/lib/javassist-3.18.1-GA.jar /home/ldl/sparkdemo/lib/javax.annotation-api-1.2.jar /home/ldl/sparkdemo/lib/javax.inject-2.4.0-b34.jar /home/ldl/sparkdemo/lib/java-xmlbuilder-1.0.jar /home/ldl/sparkdemo/lib/javax.servlet-api-3.1.0.jar /home/ldl/sparkdemo/lib/javax.ws.rs-api-2.0.1.jar /home/ldl/sparkdemo/lib/jaxb-api-2.2.2.jar /home/ldl/sparkdemo/lib/jcl-over-slf4j-1.7.16.jar /home/ldl/sparkdemo/lib/jersey-client-2.22.2.jar /home/ldl/sparkdemo/lib/jersey-common-2.22.2.jar /home/ldl/sparkdemo/lib/jersey-container-servlet-2.22.2.jar /home/ldl/sparkdemo/lib/jersey-container-servlet-core-2.22.2.jar /home/ldl/sparkdemo/lib/jersey-guava-2.22.2.jar /home/ldl/sparkdemo/lib/jersey-media-jaxb-2.22.2.jar /home/ldl/sparkdemo/lib/jersey-server-2.22.2.jar /home/ldl/sparkdemo/lib/jets3t-0.9.3.jar /home/ldl/sparkdemo/lib/jetty-util-6.1.26.jar /home/ldl/sparkdemo/lib/json4s-ast_2.10-3.2.11.jar /home/ldl/sparkdemo/lib/json4s-core_2.10-3.2.11.jar /home/ldl/sparkdemo/lib/json4s-jackson_2.10-3.2.11.jar /home/ldl/sparkdemo/lib/jsr305-1.3.9.jar /home/ldl/sparkdemo/lib/jul-to-slf4j-1.7.16.jar /home/ldl/sparkdemo/lib/kryo-shaded-3.0.3.jar /home/ldl/sparkdemo/lib/leveldbjni-all-1.8.jar /home/ldl/sparkdemo/lib/log4j-1.2.17.jar /home/ldl/sparkdemo/lib/lz4-1.3.0.jar /home/ldl/sparkdemo/lib/mail-1.4.7.jar /home/ldl/sparkdemo/lib/metrics-core-3.1.2.jar /home/ldl/sparkdemo/lib/metrics-graphite-3.1.2.jar /home/ldl/sparkdemo/lib/metrics-json-3.1.2.jar /home/ldl/sparkdemo/lib/metrics-jvm-3.1.2.jar /home/ldl/sparkdemo/lib/minlog-1.3.0.jar /home/ldl/sparkdemo/lib/mx4j-3.0.2.jar /home/ldl/sparkdemo/lib/netty-3.9.9.Final.jar /home/ldl/sparkdemo/lib/netty-all-4.0.43.Final.jar /home/ldl/sparkdemo/lib/objenesis-2.1.jar /home/ldl/sparkdemo/lib/oro-2.0.8.jar /home/ldl/sparkdemo/lib/osgi-resource-locator-1.0.1.jar /home/ldl/sparkdemo/lib/paranamer-2.3.jar /home/ldl/sparkdemo/lib/parquet-column-1.8.1.jar /home/ldl/sparkdemo/lib/parquet-common-1.8.1.jar /home/ldl/sparkdemo/lib/parquet-encoding-1.8.1.jar /home/ldl/sparkdemo/lib/parquet-format-2.3.0-incubating.jar /home/ldl/sparkdemo/lib/parquet-jackson-1.8.1.jar /home/ldl/sparkdemo/lib/protobuf-java-2.5.0.jar /home/ldl/sparkdemo/lib/py4j-0.10.4.jar /home/ldl/sparkdemo/lib/pyrolite-4.13.jar /home/ldl/sparkdemo/lib/RoaringBitmap-0.5.11.jar /home/ldl/sparkdemo/lib/slf4j-api-1.7.16.jar /home/ldl/sparkdemo/lib/slf4j-log4j12-1.7.16.jar /home/ldl/sparkdemo/lib/snappy-java-1.1.2.6.jar /home/ldl/sparkdemo/lib/stax-api-1.0-2.jar /home/ldl/sparkdemo/lib/stream-2.7.0.jar /home/ldl/sparkdemo/lib/univocity-parsers-2.2.1.jar /home/ldl/sparkdemo/lib/unused-1.0.0.jar /home/ldl/sparkdemo/lib/validation-api-1.1.0.Final.jar /home/ldl/sparkdemo/lib/xbean-asm5-shaded-4.4.jar /home/ldl/sparkdemo/lib/xercesImpl-2.9.1.jar /home/ldl/sparkdemo/lib/xml-apis-1.3.04.jar /home/ldl/sparkdemo/lib/xmlenc-0.52.jar /home/ldl/sparkdemo/lib/xz-1.0.jar /home/ldl/sparkdemo/lib/zookeeper-3.4.6.jar
